Just sharing, the colorimeter I’m using is an xRite i1 Display Pro Plus meter, also known as the Xrite Eye one display 3 pro meter. The meter has been calibrated by Pro with a higher end spectroradiometer at factory before being shipped. In short, any shortfall or errors in the meter itself, is corrected by referencing against a reference spectroradiometer. It should ideally be recalibrated over time, yearly, but I suppose I can live with that
The Display 3 pro shows errors no higher than xy0.006 for both colour and white relative to a $10,000 reference spectroradiometer. It is also able to measure down to 0.001 FL, has decent speed. Not reference grade meter but very good, good enough for SDR and HDR calibration ,DV as well and is designed and specified to measure luminance accuracy at a range up to 2000 cd/m2.
Readings will be take off the front screen for best results
The meter mode will need to be set to RAW XYZ, for this LG 810PB calibration
Auto cal needs to be set to 2020 Alpha 7 mode for it to work now
Also wise to probably set to allow the delta errors settings higher to 0.8 -1 instead of default 0.5, else it will take ages to find the best combination ( if u have time to spare that’s fine)
Pattern generator is all ready with SDR,HDR, DV all in FAT32 thumb drive, together with test pattern for aligning the PJ. Everything ready to rock. Just waiting for the hardware to arrive and hook up the unit to Ethernet and obtaining the IP of the AU810PB for auto cal
1st attempt will focus on getting the system calibrated for 2 SDR profiles in dark room
SDR pushed for deep blacks
SDR specular highlights focused
Also, calibration for HDR gaming HGiG, works differently. The pattern generator needs to come from the Xbox series X. I’ll get to that later. First will get the basics done, SDR, then HDR
All ready now for the unit
