I just saw this video from HDTV recently and was pleasantly surprised
For those who use the Sony and LG OLED and use the native built in app, this might come as an interesting topic for u.
It turns out the Ethernet port is only 100mbps, so not really maximised for streaming dolby hdr content with higher video quality ( compressed due to bandwidth limitation)
So I tested on my OLED C7
Wired speeds about 92mbps ++
Wireless connectivity in the room, varies from 7-35mbps
DAMN SLOW……
So I tried using my office usb to Ethernet , uGreen model
Doesn’t work !!
Turns out the one from cable matters might as seen on video from Vincent, also advised to turn off wifi when using the USB ports
USB 3.0 has higher speeds
There is one at the back of the LG C7 OLED, you can see from the video that usb 3.0 speeds improve up to 500mbps and usb 2.0 speeds was about 300mbps….
All the best to those using native built in app from your lg tv, u might want to get one of this to support the streaming video
On the bright side
Those using the LG laser projector AU810PB, looks like the reviews from some websites are not accurate
They claim it is a gigabit Ethernet
But my test shows otherwise
It’s like 86++ mbps wired with a CAT6 cable….
But maybe that explains why the video is at as good as using the Xbox to stream… the built in native app is not as good I find … could it be due to this ? Not sure, possibly…. If the content needs the bandwidth
