I originally thought I should set the brightness and contrast before I started calibrating and used the black and white clipping patterns on the S&M disc to set both.
However, I found that Calman reset brightness to 50 and contrast to 85 before the calibration began - right after the pre-calibration measurements so that my settings were ineffective. However, that was just my experience and I’m no expert on Calman.
Dick, a simple way to test if MadVR latest version is working is to hit Ctrl-J at this point so we can see the MadVR statistics. If Ctrl-J doesnt do anything, we know MadVR is not working. If it is working the diagnostics will allow us to see what’s happening e.g., what the nits of the scene is and what MadVR is tone mapping it to
yes it was definitely working
I always enable Ctrl J to see statistics to test my result.
I change the nits and it does effect the white output too
just the latest version somehow has lower limit of 100 which makes the scene looks very bad with clipping white .
hi,
I got another issue with very dark scene, like batman , and the black Adam while they are in the cave.
The very dark scene the black color looks banding and become like binary on and off sometimes
do you guys have similar experience and know how to fix it?
For example, this is the batman , time around 00:12:13.
No but I m saying this is one of the issues that happen on HDR source if your calibration software is not able to do a good job in HDR mode. You may want to consider calibrating in SDR BT2020 mode instead.
I watched this before I had MadVR. It worked well direct from Firestick to LG HU810 with DTM off. No access to my projector until February. Will look then
Two more important things to take note when calibrating This LG projector.
You don’t want a hd fury sitting in between the source and PJ when calibrating
The projector updates the look up table on “live basis”, meaning it inputs every read as and when each snapshot is complete. So if u had gotten to the last 8 760th reading and the PC hangs during the colour calibration process, don’t worry too much as the projector has been updated with 760 readings it has taken , losing the last 8 readings is not too bad comparing to u having to re do the whole thing again for hours .
