*Official Thread* Zidoo Z9X, Z10 Pro, Z1000 Pro, UHD3000 & Neo S/Alpha
The April Fool’s release seems to have a lot of issues. How’s the stability of 6.2.5?
I’m still on 6.1.05G…
Can elaborate what are some of the issues reported for the v6.2.0 (April Fool’s version)? I don’t see any issue. Same goes for v6.2.5. Didn’t mess much with the settings.
All those 6.2.0 issues raised @ the Zidoo forum. Such as DV playback, TV interoperability changes (EDID, DV/HDR recognition).
I see. I didn’t encounter any of those issues because I don’t use TV.
I’ll be receiving my unit soon and need a stable firmware to start on. Thanks for the info.
May I suggest starting with 6.1.05G. I have been on this version for some time, pretty stable.
Whenever you’re ready to begin living at the edge, you can update to the newer beta releases.
If you start tinkering with beta release, just a word of advise, familiarise yourself with the procedure to reinstall factory image. Reason: one cannot downgrade from newer firmware to older firmware, to downgrade- one needs to go back to factory default and then upgrade to the desired version.
Hope this helps.
If your setup allows, and if u don’t mind testing… can v6.2.5 play the 400Mbps crazy high bitrate test clip over network/NAS without stuttering?
JellyFish
On my setup, with 6.1.05G, only 200Mbps can consistently play over the network without stuttering…
For Jellyfin users, there is a modded apk that is integrated with Zidoo internal player. Try it out…
Jellyfin for Zidoo
Very sleek client, the integration still has little quirks.
On the other hand, if you’re a Kodi user, the ZDMC-Jellyfin integration works pretty well!
ps: Jellyfin is a very nice media manager.
Tested and stuttered heavily even on NFS protocol which to me has a much more consistent throughput rate over a network.
However, I am able to playback the 400Mbps version at an acceptable framerate if run on my SSD portable hard drive.
Waah, got modded UHD3000 with ESS9068 Pro DAC.
https://o5pff3g2hgyzujaimfb4mitdqi-ac5fdsxevxq4s5y-authentic-cinema-de.translate.goog/modifikation-und-tuning-av-und-hifi/4k-media-und-netzwerk-player/zidoo-uhd-3000/
Not surprise…the chasis itself is big enough for “operation” to be performed.
New Version: 6.3.0
Changelogs:
System
  1. Added the support for MP4 Dolby Vision dual-track dual-layer file.
  2. Optimized the stability of local Dolby Vision playback.
  3. Optimized system stability.
Player
  1. Optimized the display of information user interface.
  2. Added CLEARLOGO on poster wall when starting playing.
  3. Optimized some language translation.
  4. Optimized playback stability.
Poster wall
  1. Optimized the settings of the scraping source.
  2. Increased the duration sorting function.
  3. Added TVMAZE online matching for TV series.
  4. Added TVDB V4 interface function.
  5. Added local trailer only setting.
  6. Optimized the matching accuracy.
  7. When sorting by duration, the poster will show the duration of the video.
  8. Optimized scanning stability.
Music player
  1. Optimized playback stability.
  2. Optimized the interface for obtaining album cover.
  3. Fixed the problem that the bit rate of music is obtained incorrectly somtimes.
  4. Fixed the occasional issue that some audio file cannot be played.
  5. Fixed the occasional lag problem when playing some high-sampling-rate music.
  6. Fixed the problem that the data in the playlist is occasionally incorrect.
  7. Fixed the problem that the device status is incorrect after the scan occasionally flashes back.
  8. Optimized audio file sorting function.
Quick settings
  1. Added HDMI signal format settings.
  2. Optimized HDR settings.
ZD Link
  1. Added screen mirroring background playback function.
  2. Added AirPlay music screen mirroring function.
  3. Added Spotify music screen mirroring function.
  4. Optimized the problem that some video software cannot cast screen.
  5. Optimized the problem that the PC cannot be cast to the screen.
  6. Added Play/Pause key response function for screen mirroring background playback.
  7. Fixed the problem of entering into screensaver when playing video.
  8. Optimized the stability of the screen mirroring.
OTA
  1. Added beta version receiving option.
  2. Optimized partial display.
Home page
  1. Added shortcut options(For Z1000 Pro, UHD3000).
  2. Added weather display in the right top corner of the home page (For Z1000 Pro,UHD3000,weather diaplay can disable in settings).
  3. Fixed the problem that the file manager shortcut does not display.
  4. Added the application version in popup menu(For Z1000 Pro, UHD3000).
You can download from this german site: McBluna.net
Anyone here have the UHD3000 zidoo,mediaplayer,UHD3000,芝杜,媒体播放器,4K播放器,硬盘播放器,蓝光播放器
wondering how the Roon Ready option is and how external CD/DVD/BR works for legal original disk playback.
I believe bro Audio just got his hands on one unit. You may visit his forum and check with him.
Yeah will touch base over at hifive with him.
Another new beta firmware - v6.3.2
Changelogs:
System
Player
Poster wall
Music player
Quick settings
ZD Link
OTA
Home page
  2. Added weather display in the right top corner of the home page (For Z1000 Pro,UHD3000,weather display can disable in settings).
Download from this site: McBluna.net
v6.3.2G can do OTA update liao…
I just updated OTA earlier this evening…
That’s right…I’m pleasantly surprised as well. How is the d/l speed?
I guess it took just over a minute to download. If I remember correctly, I was seeing 9-12 MB/s on the screen.
That’s quite impressive speed…
