EverSolo DMP-A6 Streamer with DAC
Yes. The link is in the doc link I’ve posted. Scroll down for the link. Save to a USB drive and perform the update manually. Alternatively, you can access this direct link: https://www.mcbluna.net/wp?goto=Ii07FwVUS247ET0fEnkcQjcIQBULB14tNRRbIyYWRlk8NkcRHTQULnweEXliAFteR3cULzZBJGUKYBEaBEhYGn5pECUTGgUeZFR8RUBlSw1jQwJKOAcEL3cJFSQgBw5TZi0BJQ
Oh i see, ok noted bro :+1:
Hi, I am new here, I just got one of this and I am wondering what is the best connection to my receiver? Anthem MRX 1140. I have this options available to me, HDMI, Coaxial and Optical, which one is better?
Thanks in advanced !
It really depends on what media you playerd. For instance, if you have DSD multi-ch media, then HDMI connection is the way to go. For 2-ch music, internal player DAC played via EverSolo app is the way to go. If you have Apple Music and find the EverSolo Apple Music App a pain in the ass to use due to the horizontal aspect ratio, you can connect your Macbook Air/pro using USB-C input. Either way, you will get good sound from this DAC.
Thank you very much for the info!!!
I recently got the A8 version because I like it can play Apple music natively without airplay2.
A new beta firmware available for DMP-A6 (v.1.2.95)
Changelogs:
  1. Added separate adjustment for left and right channels in EQ
  2. Added lyrics theme to playback details interface
  3. Optimized album sorting function
  4. Added year and composer modules to the music library (To use this function, you need to rescan the music library)
  5. Added genre-based album categorization (To use this function, you need to rescan the music library)
  6. Fixed the issue of artist album tracks not being filtered
  7. Optimized the display of the playback queue interface
  8. Added embedded lyrics feature to tracks
  9. Optimized the function of adding tracks to the playback queue
  10. Improved French language display
  11. Added seamless CD playback feature
  12. Fixed occasional issue where CDs could not be ripped
  13. Optimized incorrect CD playback status
  14. Fixed incorrect order in playlist queue
  15. Optimized occasional issue where music services do not display on the main interface
  16. Added one-click account reset feature for music services
  17. Optimized cloud drive playback functionality
  18. Fixed occasional issue where UPNP device content does not display
  19. Optimized the global information prompt interface
  20. Fixed occasional issue where deleting a device also deletes the playlist
  21. Added EQ feature notification
  22. Fixed the issue with incorrect display of the number of artists
  23. Improved radio playback compatibility
  24. Optimized the music library reset function
  25. Fixed occasional crashes on the CD interface
  26. Added artist sorting feature
  27. Fixed display of external storage volume labels in file management
  28. Fixed issue with certain USB DACs not outputting DSD
  29. Added album year display in artist interface
  30. Fixed issue with certain DSD audio files not playing
  31. Fixed occasional stuttering issue with certain audio in optical outputs
  32. Resolved occasional issues with Apple Music showing a “cannot use” prompt
  33. Fixed external storage formatting functionality
  34. Optimized Cast feature
  35. Optimized filter characteristics feature
  36. Fixed occasional issue with EQ configuration renaming not succeeding
  37. Added global search functionality (This feature is currently offered on the device screen. It will be available in the mobile app within the next few weeks.)
  38. Added KKBOX to music services
  39. Fixed occasional Squeeze synchronization issue
  40. Optimized the navigation bar display
  41. Added the function of clearing data from the main interface
  42. Optimized system stability
Thanks for your info
The OTA version (1.2.98) just released.
New beta firmware v.1.3.18
Changelogs:
System
1. The digital output volume adjustment is now modified to the EVC engine.
2. Fixed the functionality where the global search for tracks would not open the playback details interface.
3. Fixed the issue where adding searched tracks to the playback queue was not functioning correctly.
4. Optimized the scanning of composer information in the music library.
5. Optimized the functionality for viewing albums and artists on TIDAL.
6. Fixed the incorrect status of local albums and artist collections in global search.
7. Optimized the sorting functionality of tracks in the music library.
8. Optimized the music library scanning to address the issue where some music files occasionally could not be added.
9. Fixed the issue where the last line of lyrics was occasionally displayed incorrectly.
10. Added the ability to add tracks from TIDAL and Qobuz to local playlists.
11. Added the functionality to import and export M3U files in local playlists.
12. Fixed the occasional failure of the music service account reset feature.
13. Added the display of DSD multichannel information in the local music library track list.
14. Optimized the sorting functionality for albums and artists in the music library.
15. Fixed the issue where the current playback information was incorrect when skipping tracks in the music library folder.
16. Optimized the quick volume adjustment to address occasional audio stuttering during playback.
17. Fixed the issue where the CUE file output by CDRip was incorrect.
18. Fixed the issue where the playback details interface would occasionally display incorrectly after clearing the playback queue.
19. Fixed the issue where the playback duration from the last session was not displayed after restarting the device.
20. Fixed the issue where Amazon Music would occasionally pause automatically during playback.
21. Added a quick setting for the Bluetooth switch.
22. Added global playlist function
23. Fixed the issue that Apple Music prompts airplane mode when connected to a wired network
24. Added the function of importing M3U files to the music library playlist
25. Added SoundCloud search to global search.
26. Fixed the issue where SoundCloud could not be logged into via Google or Facebook.
27. Fixed the issue where certain Internet radio addresses could not be played.
28. Added Apple Music music service functionality.(The built-in service has a better operating experience, but this is not a promised feature, and the highest quality is 44.1Khz. If you need higher sound quality, please use the Apple music official APP)
29. Added TuneIn Radio music service.
30. Added IDAGIO music service.
32.Added podcast subscription service
31. Added gapless playback functionality for CDs.
32. Optimized system stability
This is a OTA firmware so you should be able to upgrade it on the device itself when you check the beta version. Alternatively, you can download here.
Another new beta v.1.3.20 released today.
Changelogs:
System
* Added the feature to select files from the phone for podcasts.
* Optimized the podcast subscription feature.
* Optimized the podcast sorting feature.
* Optimized the podcast update feature.
* Added global search functionality for Apple Music.
* Added the ability to favorite tracks on Apple Music.
* Added the option to add tracks to albums and playlists on Apple Music.
* Optimized the display of certain music service interfaces.
* Fixed an issue where switching VU meters occasionally didn’t work.
* Optimized the feature for adding M3U files to playlists.
* Optimized the display of composers for certain tracks.
* Added the feature to add all tracks by a composer to playlists.
* Optimized functionalities in the playback details.
* Added the ability to import M3U8 files into playlists.
* Optimized the speed of album cover display.
* Optimized system stability.
Download here.
Another new beta v.1.3.23 released yesterday.
Changelogs:
System
  1. Optimized the music library years function
  2. Optimized the album skipping function
  3. Optimized the CD album cover and track information function
  4. Optimized the problem of the last track of CD playing being automatically looped
  5. Fixed the problem of occasional freezes when some users accessed the music folder
  6. Fixed the problem of occasional digital output volume not being able to be adjusted
  7. Fixed the problem of occasional digital output volume being too low
  8. Optimized the streaming account logout function
  9. Fixed the problem of occasional abnormal display of Apple Music interface
  10. Fixed the problem of occasional abnormal connection when ROON frequently adjusted the volume
Download here.
New beta v.1.3.30
Changelogs:
  • Optimized the album skip playback function.
  • Optimized the issue with incorrect sorting in the file manager when adding devices to the music library.
  • Optimized the reset login feature for music services.
  • Optimized the issue with abnormal next track playback in certain music services.
  • Added a show/hide setting for music services.
  • Fixed the issue where the “Select All” button was not displayed in the file manager’s edit function.
  • Fixed the incorrect data issue in the music library’s year classification.
  • Optimized the EVC volume adjustment function.
  • Optimized playback stability.
Download here.
New beta v.1.3.80
Changelogs:
  • Optimized the TuneIn Radio account login process.
  • Optimized occasional issues with TuneIn Radio failing to retrieve data.
  • Optiomized occasional display issues with KKBOX interface.
  • Added TuneIn Radio Global Search Feature
  • Optiomized the occasional track skipping issue in Radio Paradise.
  • Display Track Name While Playing Radio
  • Optimized TuneIn Radio stream quality settings.
  • Improved KKBOX login functionality.
  • Added Presto Music Service.
  • Optimized the process for modifying artist names and refreshing Internet radio data.
  • Added Laut.fm music service function.
System
  • Optimized UI operation during playback to resolve occasional playback stuttering issues.
  • Improved the functionality of adding music from music services to local playlists.
  • Enhanced the M3U playlist import function.
  • Optimized the global search functionality.
  • Added Power Key Mode Settings.
  • Added Off-Screen Notification.
  • Improved the volume passthrough feature.
  • Enhanced gapless CD playback functionality.
  • Optimized the issue where the playback queue couldn’t insert other tracks during CD playback.
  • Added PEQ Music Genre Preset Feature.
  • Added Playback Details Theme Switch Notification.
  • Fixed the occasional crash when opening the more menu in the music library list.
  • Optimized the music service editing functionality.
  • Improved EMBY playback performance.
  • Resolved the lagging issue when switching in the settings interface.
  • Optimized podcast functionality.
  • Optimized occasional issues with USB DAC volume passthrough not switching correctly.
  • Fixed the issue where some UPNP devices couldn’t retrieve data.
  • Addressed the issue of duplicate UPNP devices being scanned.
  • Apple Music Global Search Feature.
  • Added Podcast Global Search Feature
  • Enhanced the clear playback queue feature.
  • Improved gapless playback for online music services.
  • Added An Automatic Input Source Switching Feature.
  • Added search file names in the local music library function.
  • Fixed the occasional app crash issue when sliding through the file manager SMB scan list.
  • Added cover display feature for music library folders.
  • Added sorting feature for music library folders.
  • Optimized the remote control switch play mode feature.
  • Optimized the skip track feature for albums, playlists, and folders.
  • Added the shuffle playfeature to the music library.
  • Optimized system stability.
Download here.
New dmp-a6 2nd generation coming.
These are the new features released by EverSolo on their FB.
Key Features of the DMP-A6 Gen 2: (on Facebook)
• Fully balanced circuit architecture for pure, low-distortion audio output.
• HDMI ARC support for seamless integration with home theater systems.
• HDMI multi-channel support, including DSD Native and up to 5.1-channel output.
• Wake-on-LAN (WOL) for remote control anytime, anywhere.
• XMOS XU316 audio interface for effortless decoding of high-resolution audio sources.
• Dual ES9038Q2M DAC chips with master-level tuning, ensuring precise reproduction of every musical detail.
• Proprietary EOS audio engine to unlock the full potential of sound quality.
• Ultra-low-noise (40uV) linear power supply for crystal-clear audio.
• Advanced app control for intuitive and convenient music management.
• HDMI ARC and Trigger for synchronized on/off with connected devices.
• Integrated support for major music platforms and third-party apps with high-resolution direct output.
Sadly, still no support for Dolby Atmos on streaming apps. Sighz.
New beta (v1.4.60) released:
Changelogs:
  • Optimized the automatic CD playback function.
  • Optimized the screensaver clock display.
  • Fixed the occasional issue with incorrect playlist in CD loop mode.
  • Optimized the music library interface display.
  • Optimized the CD ripper interface display.
  • Optimized the album cover display for cloud storage.
  • Fixed the issue where the file manager couldn’t play CUE files.
  • Fixed the occasional automatic stop issue with “Listen at Will.”
  • Fixed the slow playback issue in the file manager with large data lists.
  • Added a globally recently played playlist.
  • Optimized the “My Favorites” feature.
  • Added more language translations.
  • Optimized the function of opening the playback details interface when playback starts.
  • Optimized system playback settings.
  • Optimized the display of Bluetooth audio input in the playback details.
  • Fixed the issue where adding a device’s playlist to the queue resulted in incorrect sorting.
  • Optimized M3U file parsing.
  • Optimized the album cover color extraction feature in playback details.
  • Optimized the large text mode display in playback details.
  • Fixed the issue where sorting in the file manager didn’t take effect.
  • Optimized the DLNA Cast function.
  • Added more operation options for the Qobuz album list.
  • Added HotMix music service feature.
Following this release, a new mobile app with new interface (for iOS and Android) has been released to take advantage of the new features in v1.4.32.
