Am using the C6. Result is good.
Hey thanks for sharing the pics. What material are you using on your ceiling above the screen?
I have a white cieling and trying to see options to darken the surrounding like you have done, looks good.
Do you know how/what different the result is with the x-rite vs the C6?
I ask because the cost is 3 times more, thanks.
Nope not tested between them. But the C6 yield good result as the meter came calibrated with certificate.
Hi all, I am ready to embark on calibrating my AU810PB projector and planning to buy to C6.
Are three any things I should know before embarking on this journey?
Should i review this thread from the begining and/or another thread?
Thank you in advance.
Has anyone been able to successfully calibrate a LG Cinebeam AU810PW with firmware 03.00.41 with the latest Calman Home Version 5.15.9.3 – December 2024 for SDR and HDR within the last few weeks?
If yes, what workflow and what additional settings did you use and how good was the result in terms of colours?
The greyscales are very good every time but the colours are bad to miserable.
If not with Calman Home, what other software, if possible with auto calibration, do you use?
Over Christmas/New Year and the first week of January I tried in vain to finish a successful calibration.
Thank you for anyones help, guide and feedback.
Regards Thomas
