Project D huh bro?
This model W4000i will be landing on our shores soon , the review is great .
The mechanical feature is great .
The price is also available SDG $4499.
Those keen do let me know . 9765 0195 Alf .
Major differences for this new BenQ model w4000i compare to most in its price range and slightly above :
A) Mid throw ( slightly shorter distance to obtain 100" 16:9 )
Hence ideal for smaller rooms , not too bulky sleek ( not claustropfobic ) Brighter hence nearer .
B) Still having full glass lens for better all round sharpness .
C) Having a 0.65 " DMD chip set also helps in the sharpness / clarity . ( More resolutions ) a better XPR processing .
D) Instead of using laser they opt to use LEDs light source . ( same life spand as laser )
@Alf , any demo for this projector?
Yes there will be demo . Awaiting BenQ Sales and Marketing Theme instructions .
Currently i have a few pre orders for my projects .
Will keep you guys posted .
Hello guys those who are keen view DEMO before buying the BenQ w4000i or HT 4455 .
So can arrange cosy discussion, trial and test .
Please put down your avatar or name:
Bro Alfi, when and where is the demo? Home trial available? Wondering how 4000W looks with madVR……
Saw this review. The sample pics look really impressive.
The other great feature about this projector is the refresh rates it can handle around.
17 .9 m/s 60 hz 4K UHD /1080 p
If settings at 1080 p setting 8.7 m/s lag .
ideal for those who wants to play on line gaming .
The TK 860i is the same chasis as the TK 850 / TK 850i and W2700.
They are all lamp base and also using the 0.47 " DMD chip .
Already got people selling in Carousell.
Yes guys it has arrived few days back . I was still playing on the settings .
The start up is very fast that is advantage with LEDs light source , it is true much brighter than TK 850 ,out of the box is great ( factory pre calibration with print out cert ) have more options calibration settings.
The fan DB level varies on the setting mode normal / smart eco / eco . There is the usuall 5 point setting + HDR brightness levels option.
Having extra brightness have more option to watch will ambient lighs ( those like to sing Karaoke ) application.
The optical lens shift with V / H options is a great to have .
It uses full glass lens and 0.65 DMD chip is much sharper .
This unit is a mid throw type same distance for the w 2700 & TK 850 . Ideal for small rooms owners who wants big picture .
Also comes with media stick which you can plug in w4000i PJ for those portable or table top mount . Those wants to mount on ceiling you can plug the stick to your AVR hdmi ports . ( like any media devices operation )
At this price it will not cost you a big chunk and have more to up grade screen size or material type .
does it support DV?
Hi bro , if you are keen on the projector and it suits your throw distance , can arrange to bring your source and DV to my test area . Hp 9765 0195 Alf …
Hi Alf,
Is changing from BenQ 5700 To W4000i considered an upgrade?
The big difference is new chip set 0.65 / full glass lens/ LED light source / short throw distance (chance to do bigger screen ).
The blacks and colours are for sure deeper , with the higher brightness it allows better HDRs to shine thru .
For sure picture is much better as i have install the 2700 / 5700/ 850i . As for demo is the same material from the very beginning which i can see the improvement .
Recent installation for existing lay out . Just need to move forward slightly the bracket and also move the HDMI Cable forward .
New w4000i with Cyrus cine PJ fixed with Titanium Grey .
Picture take by Samsung Hp camera .
