i made a call to svs technical suoport and the dsp latency of my svs pb-16 is 5.5 ms
That is good, so all you need now is physical laser distance from MLP to back of subs. then key in this 5.5ms delay in the subwoofer set up menu before you start the EQ process
ya that is perfectly fine. no issues. Have you read the manual? they have advised how to place the microphone during calibration. It is very different from Anthem. So you need to follow the recommended mic placement according to MP40 manual. I believe it will blend it nicely after that. Leave it Room Perfect, it will do a good job. no worries on the EQ programme.
Give it a try, you need not calibrate it to 100%, 95-98% of room knowledge is adequate.
once you have done that, you will need to balance the system with voicing as mentioned by DJ above.
i found the thread
its here
Moshe, hope that helps. i have written a lot on this processor in the past, in 2019. in the old forum. Take your time, lotsa information there on the Lyngdorf including time alignment stuff
Good job. Hopefully Moshe can find some answers to some of his queries. Good luck.
starting to read…thank you very much to all
a new update is released 4.2.7
Lyngdorf new speakers, the cute CUE 100 using AMT tweet with Purifi woofers… some pics below
Specs below
Interesting high end speakers with the lyngdorf brand…
very expensive speakers.
Issit very expensive ? I don’t quite like the stand… doesn’t look sturdy
Prices and Availability
The new Lyngdorf Cue-100 is manufactured in Denmark at Lyngdorf Audio’s headquarters in Skive, with a high level of craftsmanship, as the manufacturer expressly emphasizes. It is also stated that production has already started so that the speaker will be available from March 2023. The non-binding recommended retail price is at least €19,980 per pair.
and at 83dB sensitivity and 4 ohm, it will need strong muscle amp to drive it.
So ex ! Can’t believe the price is for Euro 20k !
Sir, I’m wondering what kind of DAC chip is used in MP40. Some said MP40 was superior to Anthem in terms of 2 Channels music.
Hello,
I am thinking of going for a MP-40/60… Can they play high res material (e.g. flacs with higher than 44khz) from a NAS (Synology) using DLNA?
I read they play … but from an ExFat formatted filesystem… My Synology NAS has a BFTS formatted filesystem but uses DLNA to distribute to my home-network…
