Latest updates from Lyngdorf
Release Notes:
SW 4.0.3 February 2021
- Power-up/power-down issue fix.
- Fix Output Display number of channels in DTS:X(NONE)
SW 4.0.1 February 2021
- Bug fixes for ÒDCI2.0 DCI5.1 DCI7.1Ó sources.
- DTS height channels not shown in display fixed
- Bug fixes
Specific HDMI bug fixes for MP-40:
- EDID : No-sink case has HDMI 2.0 block up to 600MHz, SCDC, DC420
- EDID : No-sink case has HDR10 and HLG support enabled
- EDID : No-sink case for 4k50 and 4k60 formats have 420 support
- EDID : DeepColor 4:2:0 support in HDMI2 block
- EDID : Forward HDR and Colorimetry blocks separately without requiring HDR10 support
- EDID : Support for HDR block luminance data forwarding
- EDID : Don’t convert 4:2:0 Capability Map Block to 4:2:0 Video Data Block
- EDID : Forward 420CAP if it exists, else forward 420VDB if it exists, don’t forward both
- CEC : Add advertised ARC audio formats for PCM, AC3, DTS, EAC3 (DV06 with Atmos, DV10 without Atmos)
SW 4.0.0
- New speaker setup generator
- Added possibility for ÒbuttkickÓ output
- More flexibility to use unused outputs.
- Added 10dB LFE gain option on PCM input on source setup
- Added web upload-function for restore-files
- Added web download-function for backup.zip-files from SD
- Updated HDMI software
- 8k TV improvements
- CEC improvements
- Updated decoder DSP software
- New IP command channel layout added
- New IP command AUDTYPEOUT
- SDDP names updated
- Bug fixes
SW 3.9.1
- Bugfix: No sound in Center Back with Dolby Upmixer on PCM5.1 input
- Bugfix: HDMI PCM 5.1 input @ 5.1 speaker setup is running Dolby upmix
- Bugfix: Dolby TrueHD Atmos Clipping at output - Cracking noise when wide speakers are present.
SW 3.9.0
- Added feature to download / upload single voicings. Voicing available for download from our webpages.
- Updated driver names for Control4 drivers
- Bugfix: that would cause a Factory Reset to fail under certain (rare) circumstances
- Values for Tone Controls, Level Trims and Loudness are now saved between sessions
- Module input routed through DSP enabling upmix.
- Bugfix: AURO upmix on PCM @ 192kHz fails
- Zone 2ch Analog Input fails when changing Decoder input
- HDMI software bug “Colorful mute”
SW 3.7.0
- Roon Ready support
- Bugfix: problem with setting Channel Gains from Web UI
- Fixed problem with Rear Dolby Enabled speakers
- Bugfix: HDMI audio off setting
- Added option to redirect LFE high part to main speakers.
SW 3.6.6:
- Bugfix: missing center channel on PCM multi-channel
- Bugfix: possible crash at boot
- Bugfix: RoomPerfect focus position names are now stored correctly
- Bugfix: Web page and info display would write 9.1.4 when decoding 9.1.6
SW3.6.3
- Bugfix: Trigger setup on sources on Setup menu
- Bugfix: Auro TOP (voG)
- Bugfix: Routing on 96kHz Dolby True HD
SW3.6.1
- Installer Menu is redesigned for faster response and allow for future updates
- Speaker and Room submenus are now in correct order for setup procedure
- Speaker Setup page now show errors, if an unacceptable setup is entered
- LFE Cutoff setting is now detailed.
- Tone controls and levels on setup page
- Bugfix: RoomPerfect Channel Gains was not updated after adding a focus position
- Bugfix: Pseudo Center channel WITH LPCM input now processed through main speakers
- Various bugfixes on menu operation and decoding
SW3.0.9:
- RoomPerfect update (note: no need for new calibration)
Includes Low frequency fix (No cut-off of frequencies below 20Hz) - bug fixes for handling source select during quick poweron (ex. from control4)
- bug fixes
SW3.0.8
- Bugfix Wake-up time from standby
- Bugfix Dolby enabled speakers
SW3.0.6:
- Bugfixes
SW3.0.6:
- Auro Clicking noise fixed
