My godpa’s oppo bd player’s remote too long never use. The battery “corroded” and it totally destroyed 2 of the metal spring contacts in the battery department until the 2 metals springs are totally gone (melted/turned into powder).
Is there any shop/person I can bring this to repair/ replace the metal contact point of the battery compartment?
Thankful for any help. Hope dont have to buy a new remote.
I used to have this issue with battery leaks. What I did was to clean the contacts with contact cleaner. Spray a generous amount around the contact areas and even on the PCB board if you are able to open the back of the remote. It worked for me after that.
In the past, there is this oppo app called oppo media control on Google play store and probably on iOS store as well but it’s no longer available on Google store. As an alternative, you can get your godfather to search for oppo media control APK on APKPure or equivalent website to download and use it. It has exactly the same functions as a physical remote.
If u manage to salvage the remote, it might be worth considering the use of “Rechargeable Batteries “ like Eneloop moving forward. Don’t have this battery leak issues
