I am going to build a home Theater.
I am looking at VAVA laser UST projector and Vividstorm screen recently.
I saw a lot of review video about Vividstorm screen on Youtube.
The introduction is quite good, the picture is clear and Vivid.
I saw there are sell on Amazon and Alibaba and some other shop.
Is there anybody who buy it from China directly?
Do you have experience to share?
Just sharing , in every products that you buy there is pros and cons . Be it the quality or is it suitable/ acclimatize to local environment as that is some thing to consider when buying it .
That in long run products will change its performance .
If you are looking for just good brightness , less sharpness and light path uniformity is not critical for PJ the UST are great product to use . If screen material are not sharp and uneven flatness at time happens and it is acceptable that the two combination will be a good decision purchase for you .
If your demand is of great sharpness , uniform brightness and long lasting PJ those conventional mid and standard throw lens PJ will be the choice. A good fiber glass base or poly vinly screen material will be ideal for you best fixed screen or motorize tab tension .
Lastly if space is constrain and like to watch with light on those item you selected will be applicable .
Yes sir , i do those physical testing by using test pattern with new type 4k /UHD with glass lens type of projector . On the screen material its self , there is also a climate environment testing to see how it reacts.
That is how my research comes to a conclusion … lah .
Hi Alf, from what you were describing here, there is a shelf life of screens and how long would that be generally speaking? Btw, my screen was made with grey screen materials, so, I would basically experience a darker picture? Is it better for me to change it to the lighter ones which I have noticed that’s been the practice nowadays? Thank you.
Hi Cnng121 , for the UST or Ultra short throw projector you can use white , light grey or with surface with optical finish . All are made of base material . The projection image will also varies depending on the type use .
In My testing room i have various type off screen material and size for different application from current standard throw , mid throw and ultra short throw .
