For those upgrading their AVR, you might wanna take note on the hdmi 2.1 port issues facing many at the moment
Apparently there are 2 versions of this, one implementation that does uncompressed signal, and another that does compressed signal
The chips inside Denon , Marantz, Yamaha’s uses chips from Panasonic that only supports compressed signal. Whilst the Xbox series X, PlayStation 5 and Nvidia uses uncompressed signal
The results are blank black screen
Another friend of mine, regretted selling his Denon 3600 for the 3700. He is facing tons of drop out issues now
This appears to be a hardware issue, not something that can be fixed with a firmware upgrade
That’s the risk for the early adopters
If you have watched that video, you might be wondering who is at fault ? AVR or the chip maker , in this case Panasonic
Here is what’s happening with the new denon 3700 when connected using its hdmi 2.1 port
Apparently it has been reported that the problems are with 4k 120fps, 8k video, but it looks like tons of other dropout issues when connected to its hdmi 2.1 port
Most probably i won’t upgrading to 2.1 since my picture and audio are of different path meaning 1 hdmi out for picture and the other for audio. Atm my tv also not supporting 8k unless with 2.1 it does make SQ another few notch up. By the time 2.1 become mature think most of us would have already change to new avr.
Yes for sure, it’s not worth upgrading now. Better to play the waiting game.
Spot on not much content
Word is that the full uncompressed hdmi 2.1 chip will not be ready until end of 2021
So it’s a long wait. If there is any intention for an upgrade, it will be year 2022 mid to end
For now, sit back and enjoy the current system with 4k, Atmos HDR and BEQ
Yes, apparently both Denon and Yamaha AVR with HDMI 2.1 had utilise the same HDMI 2.1 chipset from Panasonic. And it does seems that it cannot be fixed by a firmware update or so I read…so Sound United may be forced to recall the early models with HDMI 2.1. I agreed it is too early to jump on the 8K bandwidth but for gamers, the VRR with 10bit HDR is something that are looking forward to. Furthermore, Xbox Series X will not be using hardware-based DV, instead it will be using LLDV like Sony A1 and Zidoo Z9X which are player-led. Results may not be as good as a TV-led DV. So buyer beware…
Here is a video on that is good by Linus tech tips, some hdmi cables tested. As usual, I wouldn’t recommend the monoprice and I have said it many times in previous xtremeplace forum, the quality is just …….
See the video and u will understand…
Also why 2m / 6 foot works best !
Personally I have found moshou, zeskit, hd fury to make good hdmi cables
So if u r out shopping for one, u might wanna consider these Brands…. Others might be good too if user feedback is positive
