Was just having a chat with Gavin this morning… we talked about the dented tweeter that now seems like having a big dimple
Here is what happened to mine, sometime back
What happened was my cleaner was cleaning this, and she didn’t know and accidentally poked it…that’s how it happened…
Devastated, I looked all over the internet for a solution… and I’m glad I found one…
After that I told the cleaner. Don’t go anywhere near my system, even if it’s dusty. I’ll deal with it. So it’s important!! Lesson learnt…: but expensive lesson
How do you solve this ? Anyone ?
I’ll share what I did… when I get home
Use vaccum or duct tape lor.
I know this is a metal dome, but it may work too…
Bro u really lao Jiao !!
I had to search high and Low for answers
Ok so here is how I solve it , as desray pointed out, I used a vacuum
I got the Mrs to hold the tweeter, the. I used this type of vacuum that has the ability to adjust speed
Slowly turn it up, u don’t want to suck the whole thing out !! Slowly but surely, as u increase put your ears closer and u can hear the sound of it being fixed ( like sort of zuppp kinda sound) then take it out to confirm if it is back in order
And finally ! It was fixed !!
Dangerous , always make sure your cleaner handles it with care when cleaning
Wow this is different method…
I used vacuum, Heng it worked !! And luckily my vacuum cleaner has that option for suction power in Low incremental levels
