Hi Home Theatre fans , from the current new screen material Titanium Grey and Acoustic Transparent we have add on to motorize screen system range of products .
Titanium Grey are for user with brighter projector application , it provides a better contrast and richer colour images which a conventional white screen material will not give you that picture depth .
Acoustic Transparent screen surface are giving more option of in terms the audio placement and overall hidden clean look finish .
The screen material is white base its for those who are purist and have nice dedicated rooms or well light control environment.
Is it a ALR screen material?
And i recently bought a Vividstorm screen 120 inch ALR screen with ALR screen material.
It looks like the same as your first picture.
There is variations of ALR screens , to match the type of projector use .
The P.E.T material hard plastic feel comes with lenticular surfaces for re directing lights . Meaning it will not be smooth and less sharp compare to convetional front projection screen . This are use mainly with UST projectors.
For those who are more particular on the image sharpness they will use the traditional Poly vinly soft streatchable material , which the surface is smooth . Those using standard throw 4k / UHD projector ( Glass lens ) will be able to tell .
The tone and shade of material be it P.E.T or Poly vinly will helps on the colour richness and depth ( Calibration or Colour Settings required ) .
Basically voice down to the type of set up you are planning or going for and the quality and expectation will varies.
It has been a long while since we have customize Cyrus Cine Pj motorize screen .
Client wanted extra black drop ( as our casing and motor is larger able to retain flatness ) mounted on high ceiling , casing also custom black to match his all black theme.
After assembling the Cyrus cine Pj fixed screen it will tuck near the install place .
The screen will be wrap in plastic sheet to prevent damaging the surface and black velvet frame.
It will tuck away to prevent people touching it .
New screen material for Video Purist . Model Opti White with black backing . Ideal for Standard Throw / Mid Throw / Short Throw and Ultra Short Throw .
Having the gain of 1.15 with wide viewing cone of 170 deg and having black back will optimize the reflection light .
