Just renewed my contract with StarHub by end may will be installation. So just incase if anyone has questions to be asked I can still share what I’ve gathered so far.
There isn’t many peripherals or devices that can support this type of bandwidth. You also need to purchase a 10Gbps NIC for your PC. A 10Gbps network switch must be pretty expensive at this point.
Instead of 10Gbps, the 5Gbps package from Starhub seems more reasonable in terms of price and value. Details here: StarHub launches first-in-the-market 5Gbps broadband plan for consumers.
Hi Desray,
Yes correct would require the right equipment to fully utilise. Some of them might just think of getting the 10gbps and it will work for everything which do not understand in-depth.
The 5gbps is using ONR (I believe will be given the nokia) while the 10gbps is using ONT for StarHub.
I actually had a 10Gbps network for a few years, however I have reverted back to 1Gbps because of heat. The Asus 10Gbps router I had got hot enough to fry an egg and the Thunderbolt to 10Gbps external adapter I got for my Mac was also incredibly hot. I hope that at some point the equipment runs at reasonable temperatures before I try again. I have a QNAP NAS on Raid 5 with SSD cache and a 10Gbps PCI adapter connected to a MacBook Pro over Cat 6 cable in a far room. Used it for 4K video editing and processing photos.
Omg. I’m planning to stay with my Asus ax89x for the 10gbps. Any chance which model were you using?
What about those 2.5Gbps plans? Are they worth it?
While still waiting for my BTO to be ready in end 2026. I just gotten this, SFP+ from the AX89X to the Zyxel XGS1250-12. For my new place I’m planning to use Ubiquiti. So decided to stick with my current Asus still.
Honestly I think 1gbps is still good enough. Unless you have alot of devices connecting to the WiFi or running pretty much of servers.
I decided to get the StarHub 10gbps package because of the services I use, premier league soccer, netflix, Disney+.
Apparently the StarHub app is not locked via location like the netflix app. I’m sharing my StarHub package with my in-laws. (different location from my house) So a win win situation for me.
Actually you can subscribe to 2Gbps. One dedicated for streaming and the others for your gaming and work.
I don’t have heavy internet usage. However I often find myself downloading a full 64GB SD card from my camera (liked to the Mac via USB 3.2 SD reader) to my QNAP server. A 1Gbps line transfers around 60-70 megabytes per second, which takes about 15 minutes, whereas a 10Gbps line transfers in less than 2 minutes. That’s a difference I appreciate. The QNAP NAS has 1TB of SSD cache so the NAS HDD are no bottleneck. Also simple editing of 4K movies is much faster. Backing up the Mac or PC is also appreciably faster at 10Gbps.
Don’t think anything involving the Internet warrants 10Gbps for me so 1Gbps is enough.
Which one cannot be put in bridge mode eh? Is it the ONR or the ONT?
Wait, does it work in both places??? So i assume you have the set-top box in one place and in the other you use the starhub app on the tv or some media player box?? Do the other house also need to have starhub broadband in order for this to work? will it detect non-starhub broadband by any chance?
I’m using Nvidia shield to playback. Android devices can download the app from play store.
I did not subscribe for their box.
Yes it work both places. My in law place is M1.
My turn soon bro!
Finally ready. Signed up yesterday waiting for Aug Appt!
Time to look out for WIFI 7 router and up to specs wiredddd.
Same bro. Ubiquiti for BTO
Seems like Simba just koined the 10gbps broadband for residential market. The monthly charge is very enticing.
Just upgraded my broadband from 1Gbps to 3Gbps. No choice really as the MyRepublic 1Gbps plan expired and they are offering 3Gbps for the same $38.99 I know that Simba 10Gbps is cheaper, but prefer to wait until next contract to see the Simba reviews since MR has been very good for more than a decade. MR offered TP Link BE230 router for $50, which is cheap for a WiFi 7 router and it has 2.5G ports for both LAN and WAN. 2.5G switches and Ethernet adapters are pretty cheap compared to 10G and produce much less heat. Pretty good speed so far on my MacBook Air M3 with Plugable 2.5G adapter.
Even though the BE230 is the cheapest WiFi 7 multi gigabit router (about $150 retail, $50 from MR), my WiFi speeds also got a good boost
Best of all, my NordVPN speed to the USA went from 60Mbps to almost 400Mbps. Discovery+ and Paramount+ are noticeably more snappy. On Paramount+, I sometimes got pixelization. Now, it’s gone.
Overall, for no extra monthly charge and $50 for a WiFi 7 router, it’s a good deal. The Plugable 2.5G USB adapter was about $30 and you can buy 2.5G switches for about $50 for no name China brands. I got a Dlink from Amazon US for USD60 on sale.
I actually have a 10G switch and 10G Thunderbolt adapter, but because of the incredible heat they produce, I prefer to not to turn them on unless doing 4K video editing off the NAS. On my 3Gbps broadband, I would only get 500 mbps more speed. Not worth the heat.
Joined the game a little late as I am waiting for the 10Gbps fibre broadband plan to become more “stable” in pricing. With only $47.00 a month for 10Gbps compared to my current $74.50 for 2Gbps…it is a no-brainer and hence I switched. Of course, one cannot be naive to think that switching plan to a 10Gbps will reap you of all the benefits. Well, reality is you will need to actually spend more on your existing network gears like Router, Network switches with 10Gbe connection to really reap the benefits. So in the end, you will actually need to spend more upfront to get 10Gbps-ready. After the necessary upgrades, this is the speedtest results I have…
You will never attain true 10Gbps because there will always be some overheads involved in the processing. I have been a loyal MR customer since its launch and I am pretty happy with the results so far.
