A new firmware (with Google Play Services) release from Zidoo:
Model: Z9X
Firmware: v6.0.46_G
Download: http://apidl.zidoo.tv/Z9X/v6.0.46/Z9X_P_v6.0.46_G_202009301214_ota-package.zip
MD5: 2FEB8F6002F504C20BD91E805FA8928A
Model: Z10 Pro
Firmware: V6.0.46_G
Download: http://apidl.zidoo.tv/Z10_PRO/v6.0.46/Z10-Pro_P_v6.0.46_G_202009301320_ota-package.zip
MD5: 7373EE95928098D088270B0CB898B5B9
Model: Z1000 Pro
Firmware: V6.0.46_G
Download: http://apidl.zidoo.tv/Z1000_PRO/v6.0.46/Z1000-Pro_P_v6.0.46_G_202009301435_ota-package.zip
MD5: 25A5E308094ED015A8FC5300D3FFE76F
Changelogs
System
- Fix the problem that some TVs occasionally switch the frame rate without sound output
- Enhance local decoding and fix the problem that individual video sources cannot be played
- Fix the problem that the screen saver occasionally flashes back
- Fix the occasional lag problem of IPV6 network
- Fix the problem that some DV movies cannot be played
- Fix the problem that CEC does not take effect when closed and then opened
- Optimize online playback
Local player
- Fix the problem of occasional abnormal playback when setting single loop playback
- Add the default first audio track function
- Fix the problem of abnormal display of poster information
- Optimize the resume function
Music player
- Fix the problem of occasional playback errors
- Optimize playback stability
Picture manager
- Add global folder name exclusion function
- Add slideshow press OK button to pause function
- Add the switch whether to scan hidden files
- Optimize the display UI
- Add the function of pressing the information button to display picture information
- Add page turning function
Poster wall
- Fix the problem of playing the trailer and entering the screensaver
- Added whether to play the sound switch of the trailer
- Solve the problem of abnormal selections when the number of TV series is relatively large
- Modify partial translation
- Optimize the display interface of the edit box
- Fix the problem that the poster cannot be saved when rematching and selecting TMDB to match the TV series
- Optimize poster loading speed
- Solve the problem that the grid list interface sometimes has no focus
- Solve the problem that using Douban to match episodes cannot be classified correctly
- Fix the problem of incorrect viewing and recording data in the main interface
- Solve the problem that the list is sorted incorrectly after editing the poster title in web mode
- Fix the problem that the state is not saved after modifying the sort in card mode
- Optimize the matching success rate
- Optimize the UI display of the setting interface
File manager
- Optimize partial translation
- Fix the problem of playing record error
Quick settings
- Add the default first audio track setting
Hot key 1. Add PIP shortcut keys
2. Add shutdown shortcut
HDMI IN
- Add PIP shortcut key function
- Fix the problem that it will automatically enter the screensaver
