You can read the detailed breakdown of it on one of the sites here →
The benefits are mainly in the “Quality of data” made available to ARCG. A higher sample rate just means better quality data captured , no aliasing problems, lower noise in the upper bandwidth , lower harmonic distortion . The Anthem AVM does it natively 192/24, not upsampling
So example if you are using a mic which is poor in quality, the quality of the data suffers as well. And If you don’t have enough measurements taken from different parts of the room, ARCG will not have enough data for analysis of how these speakers & sub interact with the room. All these “captured quality data” allows ARCG to work out the appropriate parameters & filters necessary to fix the response from speakers and subwoofers in that particular room.
Note that I have said fixing the speakers in the room and not room correction. So it’s not really taking into consideration the “sound power” but rather only the on axis measurements data from the speakers. Unlike the lyngdorf that does a proper “room correction” taking the sound power response from the speakers.
Sound power can be described as the on axis response + reflected energy (early and late) to arrive at MLP
In the video that you have seen, comparisons between the trinnov and anthem AVM90 8k model, I have my doubts.
Firstly, he mentioned the system was done with a quick set up. A quick set up means it’s not optimised for the best. A good calibrator makes a big difference. I can safely say that if a good calibrator is given and entry level denon vs one who has no idea how to calibrate a lyngdorf, if u AB them, the denon will sound nicer than the lyngdorf. The calibrator plays a huge role
Secondly, the level of detail from the AKM DACs are not the same with the dynamic range you get from the sabre 9038pro. (Has to be this model, other sabre models not the same quality)
Thirdly, the choice for source used to compare. Certain tracks sound nicer. For example, if you are comparing a sound track that has a lot of emphasis for imaging, the trinnov will stand out. It has superb processing capabilities. Now if you compare a sound track like “a quiet place” that has superb dynamics and details, the AVM90 on the sabre will stand out…
Unless you have done all the above, most people won’t know the differences
That’s my view…
