I have been struggling between getting the MadVR Envy Pro Video Processor and the Lumagen Radiance Pro series to get the best 4K HDR PQ. Finally, I have made up my mind and went for the Lumagen Radiance Pro…yes, it cost me another limb. Lumagen Radiance Pro Video Processor is a bespoke video processor meant for projector owners. Ever since I got the HD Fury Vertex 2 to do LLDV…the image quality has been good for most HDR10 content. But I believe it could be better for my $21K Sony VW995ES 4K laser projector if paired with the legendary Lumagen Radiance Pro VP which does dynamic Tone Mapping (DTM) by analyzing each frame/scene on-the-fly.
I will put up a review on the image quality after calibration and hope to be awed by Lumagen’s proprietary dynamic tone mapping for 4K HDR content.
Key features of the Radiance Pro 4242+:
- Up to 4 x 4k60 UHD inputs
- Up to four processed 4k60 UltraHD video outputs at 9Ghz (or two at 18Ghz)
- Inputs and outputs support HDMI 1.x and HDMI 2.0, with HDCP 1.x or HDCP 2.2, at up to 4k60
- 9Ghz output pairs are independently programmable for video, audio, or both
- 18Ghz output pairs have 1 video+audio out and 1 audio-only output
- Modular I/O allows upgrading to new HDMI technology as it becomes available
- Proprietary Dynamic Tone Mapping (DTM) for HDR content
- Proprietary Lumagen NoRing™ scaling
- DARBEE Digital Visual Presence (DVP) enhancement technology for up to 2K sources
- Vertical keystone correction
- Supports complete processing of 2D or 3D sources
- 10-bit front-end, with 12+ bits in calibration pipeline
- Per-pixel SD/HD video deinterlacing
- 3D LUT with up to 4913 points (17x17x17) CMS
- Rec2020 colorspace and HDR supported
- 21-point Parametric Grayscale calibration
- Anamorphic screen support for up to 4k sources with and without an anamorphic lens
- Supports complete processing of 2D and 3D sources
- High-reliability external power supply rated at 34 years MTBF by manufacturer
