if any member’s having problem logging in, do remove the “S” in the https…
use http instead.
if u still cant log in, please email Audio.
Bro Audio’s email is
audio@singnet.com.sg
I’m glad to know Audio’s forum is back online. He needs to be careful from here on. I would not recommend to put the forum back online without SSL. It’s susceptible to attack. Someone may want to advise Audio to be careful during this non-SSL period.
Haha, i forgotten my password. send email already.
Attached below is Bro Audio’s reply in HardwareZone…
"It is back but it is not 100%.
You can only access it using “http://hifive.sg”…not the normal secure link “https://hifive.sg”. This is because I need to install everything again and hence it will need a new csr file and then Sectigo can issue their verified SSL cert."
(Audio)
HiFive Website is down…
just text Bro Audio, and he replied that it will probably take a few months to get back online once again…
Sad…
Hope it will get back online soon.
Yahoo!!! It’s back online once again!!!
if i can give suggestion, i would suggest that the site to take 2 days per month break to tackle with hidden issues… until the faults are worked out.
to fellow members who’re also members of hifive.sg forum, not that due to the expired certificate, u won’t be able to access to the site unless u added “www.” to the initial address u frequently/previously entered.
thks buddy, yup, the “www” prefix works.
just that u gotta “Re-Login” once again.
lucky i remembered my password.
hehehehe!!
